oh i my vibration is at the front end not rear(but i have no more tire left in the front) i went over a pothole recently and it fixed magically
it is disturbing how many tire shops suggest alignment to fix shimmy or shake...did you take in for alignment? that makes a difference according to the tire shops. but does yours shake alot? or slightly? mine the steering is no good thanks to the front tires
actually with my amgs it use to not have those vibrations but when my tires got bad they started shaking. with my pirelli tires i have no vibrations![]()
but soon i am going to try out the brabus vi multi-piece in 18x8.5 and 18x9.5 with a et35. i drove with another with oem rims and it vibrated like no tomorrow.
do you know which lugs the 97 s500 would have i need some new ones![]()
I had that with the E500 Wheels under ,they were of the Car in about 2 days ,brand new rims ,now dumped behind the garage here .i have offically seen the wheels wobble at 50-60mph like the tires are gone.
the w140 does weigh too muchtow truck guy charged a extra $75 for it. and all of the professional car lifts go down about 1/2 an inch every 10 minutes
they said it was about 2 3/4 tons at the dealer. i tried my my w211 rims on my w140 it didn't make any difference(except the rim got slightly damaged but that was the tire guys fault lol) i heard the replica brabus and amg rims are also good on the w140. i had original brabus vi and iii on my old 400sel. i also tried out the replica brabus wheels and they all were perfect
BTW the w220 has the same vibration as the w140even my cousin in law's 06 s55 has the 50-60mph shake.
do you know if 18x8 and 18x9 with a offset of 35 would fit good? also would 255/45R18 and 275/40R18 would fit on those rims?
Hi there, I think you posted in the wrong forum. The w140s were made in the period 1991-1998. Your car is much newer, likely different problem than the one discussed here.Hi. I just bought a 2016 C250d AMG line.
