1 - 8 of 8 Posts
'01 SLK-320
Anyone have a picture of where they all are? My suspension is creaking a bit (notice it mostly when getting in and out of the car) and I want to lube things up.
I
Guest
Mine creaks a bit from enter and exit also. Seems to be coming from the rear suspension on the drivers side.
Will be interested to see if there is an easy fix.
I never notice it when driving.
2001 SLK320, 2001 C320
Creaking comes from your control arm and/or sway bar bushings. Nothing to lube, just replace if needed.
I used a bit of rubber grease on all of the rubbers (they sell this stuff for assembling brakes and hydraulics) - it's liquid enough to get in- works a treat! - don't use ordinary grease - will stuff up the bushes
Oberoi
2002 SLK 32 AMG
Does it only happen if you have the emergency brake on? I think the creak on mine when entering and exiting is caused by the emergency brake, it does not occur if the brake is off. I haven't done anything about it though.
I
Guest
That's a good question. I hadn't made that connection. Will check after work. Thanks!
1 - 8 of 8 Posts
