First, context before I dive into my question: I have a '91 U.S. (California) spec 560 SEL in solid shape. I'm an avid student of H.D.'s posts (printed out and annotated in my service notebook!) and have a good working understanding of the KE Jetronic system and components. I'm able to do just about all of the core KE test procedures that don't require super specialized tools, i.e., I can do fuel pressure testing; measuring duty cycle, current, and voltage for various components; read codes at the blinky-blinky box (aka X92); etc. I have all the service manuals.
I haven't been able to locate a root cause for the following issue: during the "warming-up" phase, roughly between 55-70 degrees C on the coolant gauge, the car shows significant hesitation during part-throttle acceleration. The car runs beautifully in the preceding and subsequent modes: starts easy, "start-up enrichment" phase is fine and the car drives normally till around 55 degrees, then falls off a cliff during about 55-70 degrees, and then drives right again when it hits 70 degrees (i.e. halfway between the 60c and 80c marks). When it hits that 70c mark, it's like a light switch - full power instantly comes roaring back and all is well. During the problematic 55-70c phase, the car idles normally and starts to roll fine, but then any moderate throttle application is met with crazy hesitation and a bit of surging. If I push through to near WOT during this 55-70c phase, the car wakes up and goes.
So, what's going on here? I haven't been able to find in the service manual a detailed description of the "warming-up" phase specifically, so I'm unclear on what's suspect. The light switch-like change back to normal when the car hits 70c tells me there's something electronic that's malfunctioning or getting a false signal, and whatever that thing is is shut off or enters a different mode at 70c.
I'm confident the following components are good as all have been recently tested: EHA, IACV, 4-pole KE temperature sensor, potentiometer. For fun, I also swapped in a spare ECU that I have and the problem persists. (Both ECUs could potentially have the same issue, I guess.) Fuel pressures are good. I recently did a full KE calibration too - duty cycle / EHA current is good at idle and 2500RPM, potentiometer is set to 0.75V at about 700RPM idle.
My best guess: a partial failure of the EZL ignition unit? I know the EZL gets a temperature signal and will retard timing under certain conditions. And, the difference between the problematic 55-70c and 70c+ phases feels almost like a timing one - super retarded during 55-70c, then normal after. I think I have one spare EZL, although it's from an '88 560 and has a different part number.
I'm open to all input - things I've missed, components I should re-check, thumbs up on the EZL path...really anything. Thanks everyone! I tried to do some searching on this but didn't hit anything specific for this issue. If I missed it, steer me that way...
Recent pic of my car at Cape Disappointment for attention!
