Hi there,
I have got myself a Mercedes Sports steering wheel with proper paddles on them and nicer steering design in general..
But how do I change it? I tried the search with no luck!:( please help or is it best to take to dealers and get them to do it?
Thanks!
Dan
I'd remove the battery cables to disable the air bag first and see what can be done. I've worked on steering wheels on several different cars, but not on MB. Usually, you remove screws from the back to remove front cover/airbag and there's huge nut to remove in the middle. Spray some PB Blaster, remove the nut half way and yank the steering wheel out. You might have to pull it with someone.
**** Don't remove the middle nut. If you do, you can hurt your back or neck when the steering wheel comes out.
