1 - 17 of 17 Posts
Recently I've started to think about replacing the star on my SEL grill to a flat MB badge. Does anyone know is it possible and if it is, what parts should I use to do that?
I have a nice flat AMG replica badge (designed for the W126 grille) on mine that is a straight swap once the complete factory star set-up is removed.
It drops into the hole and is fastened by clamp and wing-nut from underneath.
Too tempting for idiots break off the factory star for a trophy if the SEL is left parked in a public place.
I was counting on your answer :wink Do you have any part numbers or a source where can I get such badge? Maybe you have photos with close-ups of the badge or the mount underneath - they will surely help me to decide to "go" or "not go" for it.
Like this?
Yup... kinda sort of like this :grin
But.......... how do you aim the car down the road without the star :confused:
It's gonna be a tough challenge but I still want to try :wink The spring on my star isn't holding it tight enough, so at higher road speeds (starting from about 100 km/h) star leans back or in some cases nearly "lies down" on the hood :crying It doesn't look nice, and I have enough of putting it in upright position every time I stop after a faster drive...
SEC's have flat badges instead of the "gun sight", don't know how they attach but probably similar to Kim's AMG badge
The SEC badge is a 107 p/n and is metal. It has a pin on it with a grommet thru an indent in the hood and a hole
No its not an SEC badge -
Its a high quality replica AMG badge of correct size with a single metal shaft with thread on the end & clamp & wingnut arrangement underneath specific for fitting to these grills.
Its very well made (much better quality than the factory Merc badge below it)
I bought it some years ago off ebay (like +5yrs ago) and can't remember who was selling them but if i recall it was out of Europe somewhere.
At the time i was seeking a replacement badge for the SEC and did not realize they are a totally different set-up with their pins underneath but when i bought the SEL i realized they were made for their grills as a replacement for the Star
Pic below
Discussion Starter #11
Thank You very much Kim :) Your help is invaluable. I'll be ordering one of those badges from ebay soon, I hope that it will look as good as Your's :) ( or maybe even better ;) )
I changed out my 107 flat hood badge for a newer sleeker one. I think from a 129. I had to mod it a little, and glue it on, but it looks MUCH better! It's the same kind as on my 216 now...
SuperModerator
Normally I prefer the upright star but that looks great. Whats happened to the little forward facing badge on the grille under where the upright star would be?
Discussion Starter #15
Because the flat badge has the exactly same pattern on it as the forward facing aluminum casted badge, I didn't wanted to give the car too heavy look, you know what I mean - too many stars in one place is a bad thing (unless we are talking about different MB models on one parking lot ;) ).
I would call this the "temporary" look. When - in some time - I'll put an AMG styling package on the car - the forward facing aluminum badge will be back on its place, and flat badge will be changed for AMG one ;)
Of course, it was another purpose for removing the forward facing badge - it was damaged, and sticked with glue to silver grille frame... I've replaced it with inox bolt, which was handly fitted to this place :wink
1 - 17 of 17 Posts
