G
Was going to use my TopSider to pump out the oil....but, the diameter of the suppied hose is too wide to fit down the dip stick tube. Anyone else run into this and work out a solution?<br>
<br>
Took a quick look under the car and it isn't obvious where the drain bolt was. Is the oil pan and drain bolt directly assessable ...or do shields first have to be removed? <p>124.cambridge-09rh16rt.ma.dial-access.att.net
