1993 - 250 GD LWB Cabrio Wolf
Does anyone know what thread size is on the speedometer shaft at the rear housing cover? I have the 750 609 transfer case and I’m in the process of ordering the parts I need to install a hall effect sender for an electronic VDO Vision speedometer. The supplier needs to know so they can supply the proper adapter. I've looked in the 460 workshop manual but I don't find any reference to the thread size.
Certainly someone has done this before. Any help would be appreciated.
Richard
1980 LWB 280GE
I have a few lying around the garage. I'll try and remember to measure one for you tonight.
-Dave G.
1980 LWB 280GE
Thread Size for 460 Speedometer output
The thread at the transfer case output for the speedometer is a 22mm x 1.5. The blade that accomplishes the drive is approximately 3mm x 10mm and protrudes 10mm from the face of the threaded portion.
If you can, please post the VDO part number for the adapter that works. I'm sure others could use the info.
-Dave G.
