· W168, W169 Moderator
A150, A180 and B200 CVT, A140, A160, A170,A190 And A210
Can someone advise if the fuel pump in this 168 accessed from inside the car or outside ie under?
You need to remove the tank to replace the pump. No other access.
If you buy the pump complete with the level sensor and plug I advise to get it from the dealer.
From experience, aftermarket (complete) pumps are for short wheel base, short wire, and level sensor for 1997-2000, otherwise it will show wrong fuel level.
To replace just the pump by itself is a bit tricky but better choice.
