My car had been having trouble starting lately, and today, it just wouldn't start period. Checked the voltage it was low. Hooked up an external charger and managed to get it started. Went for a drive to charge up the battery. Turned the car off, and once again it wouldn't start. So I figured a new battery was in order. $80 from Kragen. It appears to be just a tad bit taller than the stock one as I had to manhandle the bracket back on.
Anyway, when changing the battery, make sure the alarm is turned off beforehand. When I disconnect the positive terminal, it started going off and scared the **** out of me. After gathering my wits, I reached for my remote to turn the alarm off and that didn't work. Finally I figured that I had to reconnect the battery to use the remote and shut the thing up. That wasn't fun.
After the replacement, I started the car just fine. Now, my ESP/BAS light is on. Anyone know off hand if this is normal? Will it go away by itself? Do I have to do something?
BTW, I believe that was the origal battery on my car which was manufactured 6/2001 I believe, so that's about 3.5 years, and 27000 miles. Sound normal?
