1 - 19 of 19 Posts
1980 380 SE (Euro)
Until about 5 hours ago, i had bosch platinum core, resistor spark plugs...
i went to kragen and bought 8 of those NGK plugs, and now my car not only idles VERY smoothly, it seems like a lot of my problems went away!
vibration under hard acceleration has pretty much disappeared!
"500"sel, 560sec
leads already have resistors in them.
1982 280 se aut. ecc. - sold
NGK BP 6 ES !!
gr J
1984 500 SEL euro, 1989 560 SEL, 1980 450 SL, 1981 DeLorean, 2013 F10 BMW
Can anyone supply the part # for a 560SEL spark plug for Beru or NGK?
Regards,
Thanks for the info.
Regards,
CH4S Admin , Outstanding Contributor
1985 500SEC, 1991 190E 2.6.
Batou said:
NGK BP6ES
dunno the beru, i think it's the one in JDC's post?
Not to be negative, but how did the old spark plugs look, and how did they differ between the cylinders?
Before I changed my fuel distributor, new plugs would make the engine run good, but only for a while.
1980 380 SE (Euro)
Discussion Starter · #11 ·
hmm... they didn't look TOO bad, a bit of carbon on em, but that's about it.. i'll take pictures of them in the morning.
the gap on the old ones were also set wrong, they were at .032 instead of .042
the only thing that i really noticed was that the 3rd cylinder on the right had a bit of motor oil on the plug.... after i installed the new plugs, the 380 had blue smoke comming out of the tail pipe for about 1 min straight.
1990 420SEL 330k
what plugs do you reccomend for a 91 420sel?
what gap do they need to be also? If I buy all bosch parts: new dist. cap, dist rotor, wires and plugs is it good enough or should I buy another brand?
Moderator
Mercedes
dude... I don't know if you've read the threads in which you posted, but the answers were clearly written. The gap is written in the post just above the one you posted. The other thread said that the Bosch wires go back very quickly... that BERU is recommended. Regarding the spark plugs, this thread mentioned which ones to use or if you can find the no longer made, non-resistor plugs by Bosch.. get those.
1980 380 SE (Euro)
Discussion Starter · #16 ·
should basically be the same for all models... unless it's diesel.
for the parts you're talking about anyways.
560SEC
Snibble,
Could you please help, what is the product code for these Bosch non-resistor plugs?
Cheers.
Always Remembered RIP
1991 560SEC AMG
I am running Beru wires and NGK plugs on my 560SEC for many years, and feel confident I made the best choice, I have never had problems.
The car has 123k on it, and cruises comfortably even at speeds of 120-140 mph. (When I can find a place to do it);)
NGK BP 6ES
gr J
1 - 19 of 19 Posts
