1 - 16 of 16 Posts
I changed my fuel pump today in my 99 ml430 to fix my fuel gauge. I bought the car about a month ago knowing it had this problem and ordered the pump. After changing the pump I went to the gas station to fill the tank and the guage is now working correctly !!!!! But I also noticed that take off from a stand still was tremendously better? It wasn't running bad before but there is now a huge difference in how well the car accelerates !!! occasionally I would feel a slight miss when accelerating at medium speed. This was going to be another proj. but it is now FIXED. I got a two for one deal..... I guess the old pump had low fuel pressure? The car only has 70k on it?
Mercedes ML320
Nice deal. How much did the fuel pump cost you. My car has the same symptoms that you had, mabye i will look into a fuel pump now.
Replaced the fuel pump about a year ago on my 99 ML430, paid $215.00 for the pump. Hardest part was getting the seat back in...
Did you notice a difference?
Of course, if the car was dead before...:)
2001 CLK 320 and 2002 ML 320
When the gauge goes bad 9x outta 10 it's the FSU (Fuel Sending Unit) that has gone south..........price @ $60 w/ 1 hr to replace. I check that prior to messing w/ the fuel pump. Just my 2cents
The fuel sending unit is an integral part of the fuel pump in the 98-05 ML’s. I didn’t think you could change one without the other.
sazodada how did you change just the fuel sending unit???
How did you change the unit in only 1 hour??
Are you talking about an ML or some other vehicle??
Mike
97SL500R129, 01ML320W163, 94E320W124 & 93500EW124
Fuel sending unit is not the primary cause of fuel gauge failure. May be 3 out of 10 not 9 out of ten. Do a search and find out the real world experience of ML owners and you'll find Instrument cluster, fuel damping logic (Software) and fuel sending unit are the cause of fuel gauge failure. And based on my observation majority is caused be software or fuel damping logic.
This observation appears to be confirmed by the TSB that instruct technician not to replace Fuel sending unit or Instrument cluster without resetting the system or reprogramming the damping logic per instruction. Most of the time this procedure corrects the problem.
Also, as others said, you can't buy the sender alone. Even if you could, it won't be wise to replace the sender without replacing the pump and filter while you are there. The labor hours you'll spend to access the unit makes it cost effective to do all at the same time. Your estimate of 1 hour to replace the sending unit is probably correct when the fuel pump is out of the tank.
I just had the fuel pump/sending unit and filter replaced on my daughters 2000 ML320. The guage has been faulty since I bought it for her a few months ago. When you fill it up, it would go to empty, the yellow light would flash some, then after 20 miles or so all would be fine. But then it got worse with it dropping down to a 3/4 tank when full and you could actually watch the needle drop. Anyway, all works perfect now! And I too noticed the car was a little quicker! :D
Ken
I was trying to find out if the faulty fuel level problem in my car is from instrument cluster or fuel sending unit. I removed the Fuse #5 (instrument cluster) and put it back in. Now the gauge is back up. Before it was at the yellow light even though the tank was full. I am not sure it will remain that way after a refuel.
Where is the TSB you mentioned. I wonder removing the fuse will reset the gauge or should I do per instructions in TSB? Surely I don't how to program the damping logic.
2004 ML500 w/ Sport Package
I've had many ML's in my family, being as my family owns a mercedes dealership. All of the ones my mother has told me she had have had very tempermental gas gauges. My fathers 2001 ML320 never had a gas gauge problem, but my 2004 ML500 is somewhat tempermental, as in it will go up and down at times. This can be fixed??
MY15 C400 & MY15 ML350BT
Dude, last week I got the parts in for my struts from GermanStar.net and they were really easy to deal with. I too am in Calgary so you would have a customs broker fee through UPS but it came with no other issue and they do have the pump.
Fuel Pump/Sending Unit
Ken
How much did it cost for the repair?
1 - 16 of 16 Posts
