1 - 14 of 14 Posts
86 560sec-168K -Ext. Light Ivory/Int. Black/01 E320 4Matic Wagon Brl Silver/Black/ Mad '95 Q45
it fixed a bevy of issues
belt handlers now work
trunk light works
antenna works
air pump works
seat belt flashing gone
the fuses were all origional and noe the fuse compartment looks pretty;)
1988 Mercedes 300SE
hmmm. I would never have guessed. So they all looked ok when you inspected them? I checked a number of mine and they all looked good. Could it be just a little cheese growing in the contacts?
thats correct some cheese - i did pay extra attention to #15 cleaned out the holes where the fuse crowns. o yeah it looks pretty
1993 300SEL (Sold) 2007 X5
How old does a car have to be to benefit from changing the fuses? Mines all working ok but you never know when something might start to go south.
2015 ML 400 x 2
It's not so much an issue of age as one of keeping the contacts clean, and of course, using copper fuses.
Hmmm, mine are the silver ones not copper I guess I should think abotu changing them then?
E320
oh yes. just buy packages of them from autohausaz.com. they come in cool little pill strips. specify the copper ones. it only costs like $10 to get a whole grip of them. more than you need.
Do they come in differnt amps? I'll have to go to my local parts store this weekend and have a look.
2015 ML 400 x 2
Except Nat, I couldn't find the 8amp in copper over here, had to get them from the US.
1982 280 se aut. ecc. - sold
trunk light works
antenna works
air pump works
Told you so!
As stated search function is your friend!
gr J
Ok thanks, assuming that I can't get 8amp copper is it ok to run both copper and Al fuses? I'd assume so.
1990 SEC
jimmypop said:
...belt handlers now work...
Yup, that is how you re-set the mechanism.
If your seat belt presenter is acting up, pull the fuse to re-set the mechanism. Simple, cheap. :)
Discussion Starter #14
a3jeroen said:
Told you so!
gr J
Thats where i saw it, also pitting out 13.8 -14.1 volts now
before changes 13.8 - 12.3v
1 - 14 of 14 Posts
