1 - 20 of 31 Posts
Hey everyone,
A few weeks ago my indy changed the front wheel bearings in my 2003 E320 sedan. We also changed one of the brake pad sensors at that time, as it broke when pulling the caliper off the rotor. (We did not have the SBC unit "disabled" as we did not know it needed done until further research.)
We had the codes ABS and ESP come up, and tried most of the hints, tips and tricks on forums to no avail. We also changed the other brake pad sensor, thinking maybe it had gone bad in the process. (This time disabling and re-activating the SBC unit with the Mercedes instructions for doing so with no Star system.)
We finally broke down and took the car to our local (45 miles away) Dealer for the $100 diagnosis, which came up that our left front wheel speed (ABS) sensor was bad, and that it would be $350 to fix.
I came home, ordered the part, and changed it myself (not a hard fix.) I made sure to disconnect the SBC unit before changing the part.
I still have the same codes on the dash, can get it reset to no malfunction until I start the car, then they come right back up.
Here's my question, is there something that should be cleaned, or could have gotten dirty in the process of changing the bearings that could be causing the diagnostics to come up with a bad front left wheel speed sensor even if the sensor is good?
This issue is making me crazy, and is not good for northern Indiana winters with no ABS/ESP.
Thank you everyone who may shed some light......
Did you change bearings from both front wheels? And the MB diagnosis indicated a sensor failure only at one side of the car?
Did you replace the wheel hub sealing ring and if you did, did you use OEM parts?
Yes, both front bearings (inner and outer) were changed. The dealer said the code came up with front left wheel speed sensor only. This does make sense, as the front left would brake weird on the first stop if the codes were not yet showing and the dash read no malfunction. The codes would then come up. You could hear it almost slipping, like it wasn't sure what it should be doing.
I did not see my indy pull new seals out of the box that the bearings came in (not that they'd come with them anyway) so I would bet he put the old seals back on. Could you explain why this causes a problem, so that I can relay that info to him when I take him the new seals?
We changed out the wheel bearing seal this weekend, still same problem. When we run the reactivation of the SBC unit, where the tires are spun until the car stops them, the instructions say the brake lights should flash three times when done. However, our brake lights just come on, and do not flash.
Another question- should our mechanic have put grease in the seals, or should they have stayed dry?
When you first start the car up and drive, sometimes there are no malfunctions, but then the yellow ESP light flashes. If you try to stop, you can feel the brakes applying and releasing over and over, making the car kind of skid. As soon as the malfunctions show on the dash, the brakes "act" normal for stopping.
Purple Moderator
Going back back to the beginning. You state that the SBC was not deactivated in any way
yet the brake calipers were removed to do bearings. Then this uber tech
cant pull a sensor wire when removing the caliper? Am I missing anything?
My 13 year old daughter has done the sensor wires on two brake jobs.
There is a warning in WIS that incorrect procedure steps in working with the SBC can cause
permanent damage to the SBC control unit and/or pump.
This hangs on the over eager mechanic that took no time to research the steps. I would
tell him to get the car's brakes working or he will will face some sort of arbitration.
Nobody has any business with a wrench near a pre-2007 W211 without knowing the SBC system.
You can live with a dealer fixing and paying very sick amounts of money or let the
mechanic that screwed it up eat the repair cost to your braking system.
This is not coincidental failure. It is incompetence and he has to be the one held responsible for it.
I would trust him on the project at this point if he does
not even have a diagnostic tool that can check an ABS speed sensor. If a tech
can not communicate with theses cars then he should not even do oil changes.
The only "deactivation" was not opening doors, using keys, etc before doing any work which was several feet in the air for bearing change.
However, in the Mercedes dealership diagnosis, the SBC unit showed fine, and the only issue they could find with their diagnostic tests were the left front speed sensor. (What they say)
We changed that sensor, and from previous posts changed the real wheel seals that had not been changed during the wheel bearing change.
I can't fault my mechanic, because we knew before we went that he didn't have much experience with Mercedes, so that would be my fault.
What has been changed:
FRONT: Inner and outer bearings, brake sensors, wheel seals
Front left wheel speed (ABS) Sensor (which is what the Mercedes dealer said was wrong.)
Is there a way to reset the SBC unit? Any other work we have done since the original bearing change was done with the SBC unit disconnected.
Originally, prior to any work done, the SBC unit had been extremely loud. This was explained to Mercedes at the dealership, so that they could pay special attention to it. That is the last part still under warranty.
Thank you for your help....
Purple Moderator
At the very beginning you start off by saying this
Hey everyone,
In the same post then you write this.
Then post this.
I really can't tell you what happened as now I don't even know what happened to the SBC before the bearing change was started and the calipers came off.
My apologies. I am easily confused. :confused::surrender:
Then post this.
Thanks for your "help." As of this morning, the car is fixed.:p:thumbsup:
Anyone know what the resolution was to this??? I'm having EXACT same issues as this guy. I swapped front inner and outer bearings and seals for both left and right sides on my 05 E55. I removed caliper to get hub off. When I started car after completing the swap, I got a message saying brake pressure was low and that I should press my foot all the way to the floor and pull over. I think that was the car just getting the pads back in place where they can actually contact the brake rotor, tho. I had to press the pads back into the caliper so they'd clear the rotor in pulling the caliper off. Not sure that's relevant, but I thought I'd mention it.
Anyway, that message went away after idling the car for about 5 minutes. I then took the car for a test drive. At any speed over a fast walking pace the ESP/ABS was going nuts and trying to stop the car. I inspected the installation and it looked solid. I then got genuine Mercedes grease seals to put on there on the chance that the sensor coils/rings were incompatible with the Mercedes sensor. Have not yet put those on, but it was my plan to do so unless I'm able to come up with possible causes/fixes that are more likely. This sounds like my EXACT experience. PLEASE let me know anything you might now about this. DYING to get this fixed. Haven't been able to drive the Benz-o for two weeks now :'-(
Discussion Starter #12
Could you tell me where you purchased the bearings and seals when you replaced them- I may be able to help. Tried to PM but not sure it worked, got a blank page.
Any one found a solutions for this, I replaced front right wheel bearing (inner+outer) packed everything like it was and put back the wheel after a couple of seconds of car moving ESP ABS BAS are on, reading said C144E Check component L6/2 (right front speed sensor), so I replaced it with oem, still same issue, please help!! I clear all codes and dash is clear as soon as i drive the car again same lights show up, I tested all speed sensors and they all have same speed while car is moving and all 0 when stop
W211 ABS fault at 10 yrs. Does yr car 'Groan' ?
I just got my new (used) E280 2006 W211 serviced and got a full diagnostic done. When I mentioned the make model etc on booking, my mechanic said the one problem with that car is that at the 10 year mark, the ABS/EMS system expires and will register as a fault (Warning lights etc).
He said that you need to replace the >> ABS Pump/Module <<. They are often replaced with reconditioned units/parts also from MB. Cost quoted to fix approx $3-$3,500AUD (2015 prices) parts and labour.
The symptoms are the 'Groaning' pump sound when get when you insert the ignite key, or start the car and or when running at low speed. It sounds like a loud dog groaning as he exhales while sleeping. That's the pump over-working to maintain pressure. I gather you can send away for exchange (look online). I personally use a good Mechy with the top level 'Batcomputer' that reads these cars better than the MB dealership service centres.
Sure enough when I got the Dx results, that came up exactly as he said it would. The relevant faults listed were:
ESP: Electronic stability program - faults 6230 & 6210, and
SBC: Sensotronic brake control - faults 6258 and 65D4. (Another code is shown for each fault where the '6' is replaced with 'C2').
This is an old post but I'm sure others have the same issue. I hope it's helped someone.
Hey all, I posted #11 in October, 2012. I thought I'd comment on this thread because there are occasional posts asking what the outcome was and because I recently got a PM asking what the outcome was. Details are sketchy in my memory, but I seem to remember putting the factory inner grease seals in and that fixing the ABS issue. I'm pretty sure I would've bought the 3rd party seals off rockauto.com to save money, but can't remember the brand I got. Since you can't test whether the 3rd party seals you buy will be compatible with the ABS system until the entire wheel assembly is all put back together and drivable again, and since pulling it all apart involves a lot of work, in my opinion, saving $20ish for each seal is not worth it unless some other people have tried particular non-MB seals and found that they are, in fact, compatible. PM me if you need something as I still get the e-mails.
1 - 20 of 31 Posts
