21 - 26 of 26 Posts
2008 AMG CLK63 Conv., 2012 R350 4-Matic, Wife's 2015 C300 sedan
I don't like adding magic potions but if it worked for you and you're happy...
2006 B 200 .....& Audi A6..
What keeps that tensioner working properly ?
Is it oil pressure or just spring pressure ?
2008 B170
after adding some hydraulic lifter noise stopper additive (Liqui Moly 20004 Hydraulic Lifter Additive) rattling sound dissapeared. I believe chain tensioner couldn't get proper oil pressure because of clogged oil passage ways and this additive cleaned them. what do you think?
Excellent that it has fixed the noise, the big concern is if your theory of clogged oil passage ways is correct, then what has the servicing/oil quality/correct oils been in order to have clogged passages? Will there be other issues on the horizon from these possible sources.
Myself I would run it with this additive for about 500-1000 km and then do a complete oil and filter change using the correct MB approved oil and filter.
Discussion Starter #25
I'm using mb approved oil, actually I get oil from the dealer. I don't know if it affected other oil passage ways I'm planning to flush and renew the oil but I change oil every 5000 kms so it is a bit complicated but additive fixed the problem right away (or masked I don't know but sound dissapeared).
B180 CDI Sport 6sp '09
If you want to clean your engine, buy a new oil filter and put fresh oil ( cheaper one that fulfills all the specs) and dump it after 7-10 days of driving.
and your wasting money on Dealer oil, buy Mobil1 Super 3000 or EPS formula, or even MOTUL it's fully synthetic. Ur wasting money
Your oil already has all the needed aditives in it. I know that LM makes one of the best products. You can dislocate the bigger soot and block the oil passages. Flush with cheap oil is a much safer option for your engine.
21 - 26 of 26 Posts
