hey guys in thinking about installing ceramic pads just on the front...would recommend taking it to a dealer or doing it myself....i have changed pads on older cars but not on anything newer. i have a 2001 c240....i would greatly appreciate your input!!
Thanks!
PROUD OWNER! 2002 slk32 AMG
i can only speak for my slk but the front and rear are held on by 1 allen bolt. remove the bolt used a dead blow hammer to loosen the rotors and remove. removed calipers by removing the torx bolts and 2 bolts that hold the caliper carrier on. move caliper out of the way
highly recommend a manual and searching the forum sites for info on your model. i have found a wealth of info on my forum also mbworld, slkworld and mercedes forum just to name a few
it also helps the other forum members if you update your profile with area and model type of car if you havent already
2003 C230 Kompressor
It's one of the easiest DIY projects on the car. If you're not replacing the rotors, you'd be wize to get the rotors turned (re-surfaced) by a local shop. If not, your new pads will have a longer seating process, and your rotors will be prone to hot spots and warping. You should replace, or turn, your rotors every time you replace your pads. That way they will "seat" to eachother and last much longer. Just a thought...
