1992 500SL
The locking system on my 1992 500SL just stopped working. The lights on the door and trunk still work, however the only way to lock and unlock the doors is with the key. The key will only open the one door, not both. The internal locks are not working either. When I use the remote, the red light stays on for quite some time before going out and I hear a buzzing noise coming from the battery compartment in the trunk.... any ideas???
1992 500SL
I'll check out the vacuum pump... that's exactly where the buzzing is coming from! Thanks!
1992 500SL
Had to replace the vacuum pump... not too difficult to do. Locking system works perfectly again!
2006 SL500
If you wouldn't mind, please post some instructions. I would like to know how to fix this if it ever happens to me.
Thanks!
