Hello all,
A few weeks ago my vacuum pump took a dive so i tore it apart and discovered the motor was burnt out. So i ordered a replacement and got the pump working again. Now however i have another problem when i turn the key in the lock or use the IR sensor nothing happens at all. No clicks, no relays going, nothing. The door lights and the alarm still work so the car knows i'm trying to lock it but won't turn on the pump.
First thing i did was check all fuses and they are fine. On further investigation i took the pump apart again and discovered it does have power going to it but the relay switches on the pump for lock and unlock are not getting power. When i manually switch the relay everything locks and unlocks just fine. So something is not tripping those relays that is supposed to. Does anyone know what might cause this problem or have a wiring schematic of the central locking system so i can sort though it?
Regards
Dr. Dradle
Regards
Dr. Dradle
