Hmmm...yesterday it seems that the left-hand a/c vent has broken the little white tab and nothing seems hooked up anymore as you slide the knob left and right. The other one also popped off but I super-glued it back on.:crybaby2:
Anyone replace one of these? It appears there are some metal clips just inside that may release them for pulling them out...:confused:
Hope these are not expensive.:eek:
2008 E350 4M, 2016 Audi Allroad, 2019 Audi Q5
You won't be able to buy anything other than the entire unit. Best bet is to find a local salvage yard and get either the unit or the part that broke yourself.
Best of luck.
1995 E320
I've had the centre vent out many times, but remember to remove it, you may first have to remove the passenger side airbag if you have one. There's a screw that's hidden by the airbag that you'll need to remove before using the little metal tabs to remove the centre vent. There's lots of posts here as to how to do this. Good luck. Bob
