Phone removal
The contol in the dash can be pulled out by releasing two catches at the top, it is easy when you see it, two fingers from a bracket catch the assembly.
To remove the bracket you have to remove the bin, so you can access the screws holding it. There are (were) screws at the rear. The console portion should be a hangup cup or cradle, torx i think will open it go from there
