Hello all,<br>How to best, modified ignition system :<br>-from contactor system to full electronic system(CDI)<br>-with better coil and sparks plug wire<br>Any help would be appreciated.<br>Regards to all,<br>Agung<p><br>--------------------------------------------------------------------------------<p>
450sel 6.9
hi theres no problem to get a cdi for ure car MSD is the best system for the price like 6al its easy to conect and its a capacitive system..with means it will fire the spark will full poxer thrue out the whole rpm range up to 10kbut .from idle to full rpm in ure case its perfect,the system is called multiple spark.discharge..so when u crank it over there is multiple sparks going in to ure cumbustion chamber and will prevent a good start and throttel response to.and there is a series of sparks in 20deg.of crank rotation so up to 3000rpm there is several igniton pulses .and over 3000rpm there is only one extreme powerful spark becouse of the time it take for crank to rotate thats why .so the system is perfect.i done it my own and even doing supercharged 450sel and 6.9 awsome power
