CD Changer
901 Views 2 Replies 2 Participants Last post by  ///S320
My CD changer is skipping very bad. I just put a newly burned disc in and its horrible. All disc sleves (1 to 6) skip randomly. I know that if i put the same disc in my home cd player its fine.
So somethings wrong. What do you guys do to fix something like it? generic cd cleaners?
Thanks in advance!
///S320
2014 B250e, 2007 SL550
usually a good all arround clean up works.
I removed and cleanned all unit. Use a kit fro...
I removed and cleanned all unit. Use a kit from radio shack for the lens!
Check if the shock absorbers are working properlly.
works like a charm.
S320W
Re: usually a good all arround clean up works.I removed and cleanned all unit. Use a kit fro
works like a charm.
Hi jetkit,
Thanks, but how do i check shock absorbers? are those the springs that hold the cassette down?
About your A/C light: I have a similar problem but it comes and goes as i touch it. I think the wiring harness is bad. My dash lights are also like this. For instance my clock is sometimes lit and sometimes its not ..
