Hey, I am trying to move my changer from my ML to my C class. But when I unplug the changer from the ML the stereo turns on, but there is no sound. Is there an easy method to remedy this, with out going to the dealer?
I assume both vehicles use the D2B fiber optic bus? This bus uses a “ring� type network, so by removing the CD changer, you broke the ring. You need to complete it be connecting the ends of the two fiber cables that are now hanging loose from where you removed the CD changer. I believe there is a part you can get from the dealer that looks like a cap, but actually completes the ring. In fact, there may be on in your C-Class where you are connecting the changer.
- RODNEY
