1 - 8 of 8 Posts
300sl (r129),porsche 997, mercedes e250 cabrio (W207,280 clk (w209) rx270 lexus)
bro ,
my clk have the cd loaded into the changer ... no problem until last week when i switch to cd ,
The display shows no cd 1-6 ..
Please help...
2005 CLK200 Komp, 2007 R350
Are the CD's loaded in the correct way? Sometimes mine will say there is no CD after I put some new ones in the changer, if I take it out and put it back in it will fix the problem.
2006 CLK 350
;) Ya.. happens once in a while... take out the magazine, open each tray to make sure the CD is seated properly and not wedged or stuck, check for easy of tray swing (no binding), re-insert magazine in changer with firm pressure and hold for 5 seconds, close the sliding door, and most importantly... CROSS fingers, pray and then turn on CD again :thumbsup:
bro , tried but still the same ,is there any possibility of any wire loosening ?
2006 CLK 350
:rolleyes: Well... if crossing fingers and praying did not help .....
OK, try this...
1. Remove the magazine
2. Remove the cd changer from the glove box (unscrew/ unplug connector cables)...
3. take the wooden handle (or plastic) of a large screwdriver and rap hard all 4 sides of the unit.
4. Reattach cables/wires and Install unit back into car glove box
5. Check magazine for cperation as per last posts, be sure the Label side of the CD is up and facing you!
6. Cross fingers and Pray harder.
If that doesn't work, then go to eBay and buy another unit for $200.
CD repair
Is it reading "Magazine Empty"?
If so, check for previous posts on REPAIRING it, but i will warn you, it is a real pain in the rear.
I am going to get one on EBAY, myself.:(
Discussion Starter · #7 ·
hi bro , the readin is "no cd 1-6"
is this the same?
2006 CLK 350
Did you try any of the things I mentioned to do above? If so, which step did you leave out??
1 - 8 of 8 Posts
