2014 CLS550 4Matic
Ok. When I first got my car, it was missing the CD changer magazine. I now have a magazine, loaded it with CD's and put it in.
My questions are these:
Where is/ are the fuse(s) for the changer located? I looked in the trunk and under the hood. I only saw stereo, but not CD changer specifically.
I have no other problems with the system at all, but there is no power light, the magazine will not eject, nor will the HU recognize that it is even there?
Does anyone have a similar story that I can learn from?
I did a search, but didn't come up with anything substantial.
Thanks for any help.
-John
12E350, 12ML350, 08C350
CD Changer problem.
Take the CD changer out, in the back of the unit, there are 2 connectors : the bigger one with orange cable is fiber optic cables, the smaller plug is POWER cable, I afraid that the power cable is disconnect, if it DOES connect, there is a problem with the CD changer unit. I believe the radio & CD changer used the same fuse. Any stereo shop can check that for you, for sure there is power connector at the plug. If you need further help, PM me. Good luck.
