I just bought an Alpine CD changer for my SL320, it's compatible with the factory Bose system. I understand that this is to be installed in the trunk on the left side? Do I just remove the carpeting? I assume the cables are underneath the carpeting? Any advice or things to watch out for? Thanks!
1995 Sl320 Roadster
I have a 1995 SL320 with the integrated phone system.It has a mounting bracket in the left side if the trunk with 2 wire bundles going into the 2 boxes on the bracket.I assume that the 10 pin connector is one of the bundles.Am I right? Does anyone know if you can mount both the phone box and the CD unit together? Or does the phone have to be removed?
R129 98 sl 500
i own a 98 sl 500 w/ stock phone and cd changer they are both hooked up in the lhs of the trunk togehter in a bracket the cables for it are apparently directly behind that carpeting on the side wall of the trunk, i saw a post on how to remove the inner lining, but im not sure where it is ne more
hope some o this info was helpfull
