Hi everyone
I've got a problem with my 1994 Mercedes E320 (might be a 1993 since thats what it says on the throttle body)
the problem being that when in park or neutral the idle jumps between 600 rpm and 1100 rpm.
I have rebuilt the entire wire harness for the engine, rebuilt the wire harness for the throttle body, new gasket for throttle body, checked for vacuum leaks everywhere without any success, changed some vacuum hoses and fittings anyway and still the problem doesn't go away
error codes are on pin 8 :
4 : MAF (yes i have three of them and all of them a shot)
13: air-fuel mixture too rich or too lean
no error codes on pin 14
the thing is that when i put it in Drive or Reverse, everything is fine, idle is where it's supposed to be and everything
so I'm suspecting that the CC/ISC module is faulty, or can the MAF make such a difference in idle speed ?
one final note is that the Cruise Control doesn't work at all
