Hi Everyone!
My W140 had a bad week.
1. Climate control started only blowing out of the defroster and a little out of the side vents. This happened before and it was the Evap Temp Sensor. I was lazy and it is winter so I was going to do the Evap Sensor at Thanksgiving.
2. Climate Control will only blow COLD air!!! (see note on winter above!).
Notes:
1. I pulled ACC Ebl codes and got the expected 230 for the Evap Sensor but I also pulled a 235 Emmissions or Smog sensor??? Could this have anything to do with the cold air? I thought the smog sensor was only an issue in smog on recirculate?
2. I checked the DuoValve and it's hot, but the bottom 2 pipes (heater cores) are not hot.
3. When I did the climate control test, I did not hear all the doors opening and closing.
4. Door assist vacuum stopped working at the same time.
WHERE DO I START?
Front Vacuum Pump?
Valves behind the glove box on the cores?
Clean DuoPump?
I am trying to avoid as much trial and error as possible. THANKS IN ADVANCE!
HAPPY HOLIDAYS! Greg
Notes:
WHERE DO I START?
Front Vacuum Pump?
Clean DuoPump?
