1 - 9 of 9 Posts
2003 Mercedes CLK320
I was driving to work today and all of a sudden my radio went out and I got all these messages such as ; ESP not working, ABS not working, tele-aid not working etc. The scariest part was that my turn signals weren't working either on the fwy so I couldn't change lanes. Then I went through the menu and I went to "audio" and adjusted it and it worked again. It was scary though!!
Does anyone have a clue what was wrong with my car??? Do you think it's the batter? Cause the first message that popped up was the battery sign, but after that i received a plethora of error messages.
I have also had an issue with the keyless remote not opening my doors at time, forcing me to use the metal key. It's on and off. Not sure if that is related.
What MM said, The ABS and ESP are known to come on at low voltage.
Question is what cost low voltage? Battery or alternator failure alone should not have the effect since those thing back up each other at least for some time.
The only explanation for sudden voltage drop that went away would be big short draining the power.
Since that is safety issue, I would go over all big electrical wires with magnifying glass.
Which of the followings may explain the above symptoms?
a) Battery
b) Alternator
c) Loose wires
d) Top secret military EMF experiment
e) UFO
I called mbenz roadside assistance, they tested the battery and said it's showing 12 volts instead of 14 so it could be the alternator or regulator.
Normally, I would take it to this independent mechanic specializing in benz that i trust. he would have tested what was wrong with it for FREE, but it's 30 miles from my work and I don't know if my car would have made it there. So i had no choice but to take my car to the Benz dealer to have it looked into where they charge $100 just for the test! Reason is because I live around 20 miles away from work and I needed a loaner car. I don't get off work till 5 and I would not have enough time to drive to my mechanic and go to enterprise rent a car since they close at 6!
I have NO ONE to drive me to work (around 20 miles each way), I had no choice but to go to the dealer who will charge me around $400 more than mechanic I know, but I needed a loaner car and if i didn't have one I wouldn't be able to get to work.
If it's the regulator Benz dealer will charge me around $300 and if it's alternator probably around $800. The regular import mechanic would have done it for $150 but I can't risk my waiting until the weekends and having my turn signals not working on the freeway.
Benz left a message on my vm, to replace/fix the voltage regulator is $388 and if it's the alternator it will cost $990. I am going to have my mechanic take care of it.
1962 W111 220SE Coupe
Hi Jackie, you may wish to familiarize yourself with hand signals for turns and lane changes should you find yourself in this situation again. Basically extend your left arm straight out to indicate "left" and straight up bent at the elbow to indicate a "right". Bent straight down indicates a stop. Of course other drivers may not be familiar with these signals in this day and age so use caution, but at very least you are getting their attention and these signals are legal so that will prevent you from receiving a ticket. Also, MB provides a free tow to their dealership within 30-miles so you could also simply pull over somewhere safe and wait for them. This is a service they offer to ANY MB owner for ANY car, regardless of age, mileage, warranty status, etc.
Finally, I was under the impression that Enterprise delivers rental vehicles to your location free of charge, at least according to their commercials, which would allow you to take your troubled Benz to the mechanic of your choice. I know it's difficult to always think things through as thoroughly as we might prefer when we're faced with challenges involving our cars, I am guilty as well, but I hope these suggestions will help in the future.
Good luck with your car.
If my car's turn signals don't work on the freeway, I'd rather maneuver the car, speed up slow down squeeze in or out get to the right. I will not stick my arm out the open window at 70mph.
Fair enough but luckily for us, Mercedes has appointed every vehicle they make with an exotic but little-known device called a "brake pedal." It helps to slow the vehicle to a more reasonable speed for undertaking such adventurous maneuvers. :)
1 - 9 of 9 Posts
