2004 E320
I have recently had an issue when I turn the key, nothing happens. The car does not crank or make a sound. All the electrical works but no engine. I turn the key off and turn it again and it starts up. Could this be a battery issue?
Banned
1999 E300 TD
Could very well be a battery, however to confirm take the car to an Auto Zone or Advance Auto------------they will check the charging system for---FREE
Good Luck
Wrong forum since you have a 2004 E320, that's a W211. That said, if your battery is the original you could be on borrowed time. As advised have some auto parts place check your charging system. There's also a slight possibility your EIS might be to blame.
'01-E320 & 02-ST2
Plus one on the wrong forum.
Your W211 has two batteries, so it's possible the primary has failed.
Call roadside assistance; they can do a quick check for free and will sell and install a new battery for just the cost of the battery, no labor.
You could also search/post in the correct forum if you want a little more info before calling.
