1993 300CE
I searched, and this may sound a little repetitive, but the situation is a bit unique. I disconnected my battery a dew days ago when it was nearly dead to reset the radio (I had a problem with it, it's fixed now). I reconnected the battery and put the charger on. I plugged the charger in and it popped and a a spark and smoke came out of the charger. I used an old charger I have and charged it, but it hasn't charged. The car isn't turning over, so I'm wondering if it's something with the car (starter or etc.) or the battery. Thanks, M44
2013 E350 sedan, 2013 E350 cab, 1993 400E sold,1999 ML320
battery
If it wont do anything and there is power in the battery check the fuses first. after that battery. Do you have any lights or anything?
1986 mercedes benz amg 420
not to sure but could be alternater thing i kno if pos and neg terminals get mixed up it could fry some wiring to the alternater as well as a bad alt would keep draining your battery
1993 300CE
Yes, I have lights, and the fuses check out ok. Am I looking at replacing the starter or alternator? And how much will this end up costing?
W124 Moderator
I would pull that battery and try another one first. It could have reversed polarity.
Jayare
1993 300CE
I pulled the battery and dropped another one in. Started right up. Thanks for the help, I'll be getting a new battery on Monday.
