1996 E320, 1998 E320, 1997 Acura RL
Car will not start in Park Position
My 1996 E320 will only start when the shifter is in the Neutral Position. It will not start in the Park position. I will appreciate if anyone that can help. I understand that folks who own W124 would know better. I will appreciate any help.
Most likely it is a issue with the neutral safety switch on the transmission. Alternatively, it could be a wiring issue going to the switch if your car has eco junk wiring issues which troubled all MBs made between 92-97.
85 300 TDT
Wholeheartedly agree. Something all of us have experienced at one point...
Although most of the 96s - I believe - had the updated harnesses, if you want to check just find a section that has the wires feeding into it and gently roll between your finger and thumb. Nothing should crack, crinkle or fall off.
Eco junk wiring issues cannot be ruled unless the vehicles was made after Jan 1998.
Thanks guys. I will check the wiring and the switch as suggested. I did try another opinion from the W210 forum, which suggested that I move the shifter side to side. So far, the car is starting, and hope it stays like that. I should mention that this problem kind of comes and go. The car, also tends to move forward/backward quite a bit when parked.....depending on the up/down (driveway) slope. I only have 102k miles on the car!!!!!!
