The blue electrolytic capacitor should be just fine if you resolder it back in, very important to get it the right way round, stripe is negative, tell tale signs of failure are bulging at the top.
A good clean and dry should sort the PCB out.
There is a lot of info on the transmission on here, make sure the fluid level is correct and replace the connector seals (that's how your ECU got wet).
