MY01 E430; ~190K
It has been unseasonably extremely cold where I am (low single digits to sub zero), and very windy. Car has been sitting outside for several days. Had tranny service done 2.5-weeks ago, drives great. This morning the car started fine - usually let it go to idle, but it was way too cold and I was in PJs, so I shifted as the revs was dropping. Car stalled immediately. Restarted, let revs drop again to near idle, shifted, same results. Restarted, let idle for a few minutes as I stayed indoors and all has been fine since. Is this some kind of safety mechanism kicking in or do I have a problem?
1998 E320 sedan
I still think it’s the oil!
What I am assuming is that the engine is in proper working order.
You have just had an oil change done on the transmission. You have found that this has improved the performance in general.
However when it is extremely cold the engine stalls when you engage the transmission; BUT when the vehicle is at operating temp there appears to be no issues. Is that right?
So it’s the oil! How come? Things we don’t know: how much oil was replaced? Was the transmission flushed? What if anything was found in the filter? What was the “sludge” like on the inside surface of the pan? (an indicator)
Sludge is not just privy to the pan but throughout the transmission and torque converter. Now as we know transmissions are finally machined units, and the characteristics of the oil used are carefully selected. The stability of the fluid in a new transmission can be predicted (doesn't mean they always get it right) but all bets are off after an overdue oil change!
You can easily remove the fluid however it’s not easy to remove the sludge. Let us say we replaced 11lts, that is a good count and you now have lots of fresh fluid, which is also a very good penetrant! That begins to change the characteristics of the fresh oil as it is now dissolving the sludge and blending with the old! This dissolved sludge now mixes with the fresh oil changing it, and no the filter can’t help as it isn't designed to.
So what is going on that the engine stalls only when very cold?. The short answer is the solenoids are wasting amps because they have to work against the sludge, heaver oil, cold temperatures, and age. Speed is important here; when you engage the transmission the actuators have to respond fast that's there design. If they slow or stall then the torque converter bypass, or slip isn't functioning properly, it cloud be just dragging or not slipping enough, engaged verses engaging, or lockup mode (and no it shouldn't be) at to low RPMs! Here is a quick example, if any one reading this remembers the old “fire ball” cams, or any other high lift, 1st thing we needed to do was find a new stall speed and that also meant a higher stall torque. What that means is a stock torque converter would engage at to low an RPM and cause the engine to stall out! We now had lots of potential HP however we needed to control the engaging at higher RPMs. (a short explanation)
That is what I think is happening, though the cause is different, for one the oil wasn't changed often enough, sludge built up in the valve body, slowing or stalling flow regulation and or path.
Hot oil achieves a better working viscosity; that coupled with the hot valve body mass, things actuate closer to design. I think that if you keep up with the oil changes and perhaps drop some and replace more when the color starts to change, likely you will get ahead of it, or drop the valve body and clean it.
We can also describe the stalling as, dropping the clutch at 6 or 700 rpm!
Try this it won't cost you anything and I don't know for certain it will boost enough but might help, put the air conditioning on 15 seconds before engaging the trans, if it helps drive a couple of blocks with AC on then switch to heat.
Patch
That's right. Thanks for the detailed explanation below. I tend to agree with you.
Hot oil achieves a better working viscosity; that coupled with the hot valve body mass, things actuate closer to design. I think that if you keep up with the oil changes and perhaps drop some and replace more when the color starts to change, likely you will get ahead of it, or drop the valve body and clean it....
Well, this is the second tranny service since factory fill. The first one happened at just over 80K, so in my estimation, I don't think it is lack of maintenance. Same guy does mine and he also does my ML and BMW - ex MB master tech, does only MB and BMW. We have talked sludge regarding the MB/BMW so called lifetime tranny, so he keeps an eye on it for me. This time, he says fluid was clean coming out, no metal filings, nothing unusual. When I did my 325i last year, he said some bad things about the tranny fluid he drained. On my bill, I see QTY=4 for fluid purchased - I assume that is 4 qrts of tranny fluid purchased, and supposedly put in 4 qrts? In any case, it was just as cold this morning but all went well. It very well could still be sludge, I'll keep an eye on it. Again, thanks for the detailed response.
1998 E320 sedan
Hey Darkmann, and thanks for replying. I wanted to ask if you use the winter mode? You likely know that the cold shifting is programmed in, if memory serves I think till 50c is reached.
Regarding the oil quantity, 4 QTs could be an extra 4, over the base oil change price for the MB? And no four QTs as an oil change isn't enough.
See you around
Patch
Discussion Starter · #5 ·
See you around
Patch
I know about the cold shifting, but don't know what winter mode is. Do you mean the two modes on the shifter? If that's what you mean, I rarely use the W mode since I rarely drive the car in the winter. I think of the W mode as the Lo range on the ML - lets one take off very gently on slippery pavement. Does that mode do anything other than that?
1998 E320 sedan
Standard/Winter, my understanding is in W when you shift to D it will engage 2nd gear not 1st.
Also the ratios are changed including Reverse! You being a torque lover from of the 500 you have, can see the advantage of switching between both depending on conditions.
No W is not low range like a 4x4 low gear pulling torque.
Try W next time you use the 430, see if it helps with the stall. Also don't dismiss the AC trial when engaging the transmission. Even though the RPM is programmed to settle down you are still calling for ECM to increase pulse due to compressor load, that could tip those cold engagements in your favor! Won't know till you try.
Patch
