I finally went and got the car back from Mitch Carr Auto. They said the transmission is fine, and it is a seasonal behavior! Once summer comes it may return to normal. I can't understand this. But they found other problems and insisted that they were very dangerous. The first problem - front brake calipers were leaking and had corroded the brake rotors. Only a few months back I changed the front pads and I did not notice anything. Probably I did not know where to look. I did notice that the brakes were acting in a funny way. Since the mechanics were opening up everything down there, they also wanted to change the wheel bearings, as it is 2.4K miles old. Here is the cost for brake and front suspension job.
Set of Rebuilt Front Brake Calipers = $188.00
Set of Front Brake Pads = $62.00
Set of Front Rotors = $200.00
4 Brake Sensors = $20.00
1 Brake Fluid = $6.00
2 Brake Hoses = $90.00
Set of Front Wheel Bearings = $200.00
Labor (Remove and replace front brake system and bearings, top off brake fluid) = $720.00
Cost for this set of repairs = $1486.00
The brakes are functioning fine now. Except that I have to depress the brake pedal way down to stop the car. Before just touching and depressing the pedal a little will slow down the car. Not sure why. (Initially they quoted more and said that the ABS may have damages, but then found that the ABS was not damaged, otherwise total cost would have touched $3.1K).
