2010 SL63 AMG, 2001 SL500, 2012 Corvette Z06, 2013 Lexus RX350, 2012 Cadillac CTS Coupe, 2015 Ram
I have a dilemma here. My 2010 SL63 is in my garage with the top down. The top won't go up and it is rainy, so I'm unsure of how I can get to a dealer.
I suspect the problem might originate with the notorious leaky trunk "soft-close" actuator. First symptom I noticed was the pump coming on more and for longer when I start the car. Then I noticed when I put the trunk lid down it would slam instead of doing the soft close. This went on for a while, then the other day I discovered that the trunk lid would not go up on its own. I had to forcefully pull it up, and the lowered top inside the trunk would not tilt up to give access to the storage space. The trunk lid would close normally (other than the slam) when I pressed the button to close it. Then I realized I couldn't put the top up either. I can hear a relay in the fuse panel behind the passenger seat, but nothing else, and that pump isn't going on. The trunk battery is fully charged.
The related threads I have read refer to a circuit that will disable itself because of an air leak, and can be reset temporarily by pulling a fuse. However, different instructions seem to point to different fuses. I tried pulling quite a few of them, but no luck. Either I'm not getting the right one, or I'm not waiting long enough, or the cause of the problem is something else.
I'm just hoping to get the top up so I can investigate further to DIY or get it to a dealer.
This is a lightly used, pampered car with no wear and tear - about 25,000km (16,000 miles), always garaged at home and never winter driven.
