1997 E420 Sport & 2003 E 500 Sport & 2005 Covette C6
My 2003 E 500 stopped being able to open and close the windows with the smart key (the summer opening feature). Its when you press and hold the lock button on the key and point it to the drivers side lock and it would close my sunroof and lock my doors and would close opened windows; and vice-versa when you unlock. I noticed it "only works now from the passenger's side lock" as I press the button on the key, not the driver's side as it used to. Maybe a sensor not working? Help please?? :bowdown:
223.168 & 213.050 & 906.633
My 2003 E 500 stopped being able to open and close the windows with the smart key (the summer opening feature). Its when you press and hold the lock button on the key and point it to the drivers side lock and it would close my sunroof and lock my doors and would close opened windows; and vice-versa when you unlock. I noticed it only works now from the drivers side lock as I press the button on the key, not the driver's side. Maybe a sensor not working? Help please?? :bowdown:
I guess you mean it works on the passenger side but not on the driver's side? If it works from one side but not the other, I cannot see anything else possible than the IR sensors being faulty at the door handle. Theoretically some wiring but quite unlikely.
I had the same problem, the Smart key opened the windows and roof from the passenger side only, but not the driver's side. More than likely, it is the IR sensor located in the lock cylinder. The lock cylinder is about $130.00 and installation approximately an hour. To get a replacement lock cylinder, you will probably have to get it from the MB dealer because MB cracked down back in November on security and the documentation to get a replacement.
Also, try replacing the batteries in the remotes as they tend to get lazy as the batteries get weaker.
