1 - 13 of 13 Posts
300SD
I can't hear my turn signal blinker. Has anyone solved this problem. My repair service did not have a solution.[V]
1991 300 SE
I assume you have some kind of Mercedes-Benz automobile?
(they’re not all the same, you know…)
300SD
Actually, I have two, a 1984 300SD and a 1985 380SL. I am older, but I have a hearing aid that is excellent. My diesel is a little noisy, but it seems to me that the blinker noise could be made a little louder.
2002 430clk;2005 Yamaha YZF R1;08 Range Rover Sport
Blinker noise? I would be upset if I heard mine
Hi all,
I have a similar problem here. My car is C200 Esprit 1996 and all of a suddent, the turning signals stopped flashing. When I indicate, the right light turns on but never flashes ?
Any idea what may have caused this issue ?
Please help [:(] [?]
1991 300 SE
I’m not that familiar with the newer cars; in the older cars the dash indicator blinks very quickly when a bulb is out – in the newer cars it’s possible the indicator light in the dash will stay on.
300SEL 6.3 W109 type
Funny, on my 1981 300D turbo my blinker recently started making this wierd sound instead of the blink that it usually made. It's like it about to die.
On my 300TE 1989 model there is a sound underneath the dash that sounds like the blinkers but never stops unless I use the turn signals and my fuel gauge is not working. This just happened tonight and I'm looking for a solution.
1 - 13 of 13 Posts
