1972 350SL 4.5, car #917
So now that the trip is over the sorting out can start. Manual is on order, so working a bit blind here, but this appears to be a grommet for part of the harness. If that is the case, any reason to be concerned about the tear where the red arrow is pointing? Am I missing part of a circuit/wire there?
Thanks guys.
1977 450SL
Those nipples are extra ports you can open up to run other wires into the cabin. I used the one you pointed to to run a hot wire into the cab for the new Kenwood so it would have hot to the programming with key off.
Ah - thanks. So good place to run a 12v line in to the cockpit for a phone charger then, yes?
Thanks.
