Here's the correct link - the previous one didn't seem to work properly.<br> <br> http://www.tirerack.com/tires/tiretech/general/speed.htm<br> <br> One question I have - given two equivalent tires in terms of model and size, do you sacrifice anything in terms of comfort or tire life for a higher speed rating?<br> <br> I had a choice between ZR and YR tires and took the YR, for the higher speed rating, for those regular days when I'm doing 186mph <br> <br> Any ideas?
I think that it really depends on the specific tire and manufacturer. A higher speed rating means that the tire can generate more heat and take it. Construction will most likely be different (better). Tread compound might be different. Tread pattern might be different. I don't know if the 'in general' question is a valid one that can be answered....
Hello all
I've never owned such a fancy car. Can I use a floor Jack and stands and rotate my tires at home? I was wondering if I somehow need to tell the computer that the wheels are now on a different spot. Someone mentioned a diagnostic tool was needed to be plugged in to the On Board...
In my 2012 S65 I hit a big pothole and blew out my left front sidewall (sounded like an explosion from inside the car). I replaced the tire, and a couple thousand miles later I noticed significant wear on the inside edges of both front tires. I took it in to the dealer for an alignment and the...
I bought an A-class automatic 10 months ago. Since then I have driven 22K km of which I’d say 85% of this was straight motorway and minimal breaking.
I’ve just brought my car in for a service to the garage I bought it from and they told me that after 10 months, my brakes are worn to 90% with...
Hi all,
After replacing rear airbag suspension for my E350 Wagon 2007, I'm still seeing a malfunction message on the cluster with the arrow under the car. My mechanic assures me that all is in order. Does anyone know how i can delete this message?
Fellas:
I am in the process of converting my 1991 560SEC to the NON self leveling susupension. Besides the rear shocks and springs from a NON SLS car, what all needs to be done? Can the Hydraulic setup be plugged? Do I have to repace the front shocks and springs as well?
The car is currently...
