1998 E320s sedan and wagon
I missed a breather hose after resealing the valve cover breathers. I got P0170 and P0173 late during a lengthy test drive. I haven’t driven it after fitting the breather hose. Could it be the loose hose caused those codes or is it more likely the MAF sensor?
Sixto
98 E320 wagon 197K miles
Yes it will. Could be also a bad MAF too, but unmetered air after MAF will cause lean codes.
1998 E320 base sedan @ 160kmiles
If you did not have those codes before the repair, it is more likely a vacuum leak after the MAF sensor.
