1999 E300D-TD, 1984 300TD
Sorry if this has been asked, but I did a search and couldn't find an answer.
Can I use the pictured primary fuel filter on a 1984 TD?
After taking the time to drive to the parts store, I saw they were selling me what appeared to be the incorrect part, despite having the correct part number (A0014776601).
I bought it on the off chance it would be okay to use. Figured I would likely end up having to make another trip, anyway, if I needed to return it.
All of the in-lines I see are the clear, bulbous type.
I just want to make sure it is rated to the proper micron filtration level, or else I won't use it.
So what is the consensus?
TIA.
Can't see through it enough to give any advice, but most of those are more of a screen than a filter, per se.
1985 300CD Turbo coupe, 2006 E320 CDI sedan
As long as it fits the hose diameter without leaking, I don't see why it wouldn't work. It's not all that different than the one I have on my spares shelf. In fact, I may have used on of that shape myself over the years. Fuel flow should be from the straight end to the 90 degree end.
//greg//
81' 300SD, 82' 300D
I've used both types of filters pictured. It's ok to use.
