1 - 9 of 9 Posts
2004 CLK500 Cabriolet 2014 Mustang convertible 2016 C300 (wifes car) 55 TBird Old ford truck
Is it ok to use the Pentosin fluid in my hydraulic system on my CLK500?
There isnt a MB dealer around here and Pentosin is all thats available.
· Coupe/Convertible Forums Moderator
CURRENT: 2011 SL550 FORMER: C300, ML350, CLK550 Cabriolet, C240, ML320, 300TD
For the convertible top hydraulics? Yes, you can. However, if you ever get a leak in the front lock cylinder, you'll wish you hadn't - it will stain the headliner and stink.
2005 CLK55 AMG Coupe ,CLK320,Former,C180 Kompressor,Jensen Healey,Ford Capri V6,Alfa GTV.
Maybe try ebay.
MB spec.345.0 Green, power steering hydraulic fluid..Febi Bilstein Nr 21647
or,, MB spec 236.3 Yellow, power steering hydraulic fluid Febi Bilstein Nr 08972.
Green is used for below freezing environments I think.
00' E320, 03' E320T, 05' C230K
Discussion Starter · #6 ·
My front latch has blown its seals already. It has been sent off to Klaus for repair. Top is stained a bit . Just trying to see what will work before I try something that wont. Waiting on cylinder to come back.
Discussion Starter · #9 ·
Been trying to contact Klaus for 3 days now and getting no response. So, I went to the big city and stopped at the MB dealer and bought some fluid. If my cylinder ever gets here I have something to use that works.
1 - 9 of 9 Posts
