'02 e430 4matic
So I need a front Propeller Shaft on my '02 e430.. part number 2104103716
dealer wanted $1100 for the part alone..
found a company in Tx Driveshaft Specialist Inc
that has 4matic front drive shafts... i asked for an '02 e430 and he didnt have it.. i asked if he had an '02 e320 Front propeller shaft and he said yes..
can I use the 320 shaft?? i cannot find the part number on it.... I got the e430 part number cause I subscribed to alldataDIY but it'll only give me MY part numbers...
anyone?!?
thanks in advance..
Jamie
'01-E320 & 02-ST2
Sign up for the EPC and look up the part numbers and compare, that's the easiest way to know. Link is in the stickies, they require a credit card to verify you're in the US, but it's free.
I can tell you right away that it won't fit.
The flex disks on the 320 have 6 holes. Those on the 430 have 8.
'02 e430 4matic
Front propeller shaft doesn't connect directly to the flex disc like the one going to the rear wheels Matt
'02 e430 4matic
Thanks Greg
i did what you said....
and....bingo.. or as we say here in NewHampshire
es lo mismo
I'm in luck thanks again
