9191 Mercedes 300ce
Hello all , I have a 91 300ce . Abuddy of mines is junking his 94 s500 and I want to take the brake system from him.Will they work ?
W124 Moderator
Your CE has a pretty robust brake system as it is. In 90, when the CEs got the M104 motor, they also got much larger brakes, lower final drive ratio, larger rear diff. etc. etc. I believe the parts will swap, but not certain if you'd really feel the difference. Measure the rotor diameter of each and see if there is a significant difference. I doubt there is.
Good Luck,
Jayare
