1 - 1 of 1 Posts
R129 sl320 '99 / W201 190E '90
Here is my problem-
When I went from D to R the car did not recognise and left me in N I think and this happened twice. I asked the Specialist who recently rebuilt my gearbox and he suggested it was some switch under the gear lever but when he plugged it into the computer he suggested that the problem was a CAN fault which would not be cleared and which could be very complicated.
This is on the print out
Motor Electronics 2
P1681-154 Crash signal implausable current and stored
P1747-062 CAN fault not defined
ETC - Electronic transmission control
97 Test fault (ignore) stored
136 CAN comminication with control unit instrument cluster is sporadically disturbed stored
ICM- Instrument cluster with maintenance interval display
B1040 Fault in CAN communication with control unit MR engine control stored
B1041 Fault in CAN communication with control unit Traction systems stored
B1042 Fault in CAN communication with control unit BAS brake assist
B1745 The serial interface K1 of control module AAC to control module instrument cluster has -- + stored
B1755-001 The serial interface K2 of control module AAC to control module instrument cluster has -- + stored
B1755-000 The serial interface K1 of control module AAC to control module instrument cluster has -- - stored
If anyone gets the chance I would greatly appreciate your response.
Regards and thanks in advance,
Darragh
1 - 1 of 1 Posts
