1 - 9 of 9 Posts
ML350 04', ML 320 00', G-460 86'
Is it one common CAN bus in this car connecting all the module or do does it exist several independent can buses? it's a little difficult to decide from the wiring schematics.
2004 CLK 240 Coupe
It's not possible to generalize here. I have identified Can-B, Can-C, MOST and LIN bus. Some systems use only one, others use more than one.
For example, transmission uses only Can-C bus. Airbags, Horn, Parktronic use both Can-B and Can-C.
Radio control uses MOST, Can -B and Can-C. Heated seats use Can-B and LIN. It is not simple. :(
· Outstanding Contributor - Always Remembered, RIP
Zotye Auto 1.5T T600 2016
If I can clarify this a little, all MB BMW and most other modern German cars use more than one Control Area Network. The different CAN bus systems do sometimes use the same wiring but rarely.
2004 CLK 240 Coupe
nilstores - could you do the forum the courtesy of filling in some details with UserCP ^^^ to let us know your location, etc.
From your previous thread on this topic, you are mainly interested in the engine control, which is handled by CAN-C. Can-B is used for Interior control functions.
The BUS/module connection details can be put on 5 jpeg images using a screen grab from my WIS DVD. If you pm me with an email address, I will send those images as attachments which you can then print out.
1 - 9 of 9 Posts
