1 - 10 of 10 Posts
92 190e 2.6 Sportline, 2005 clk55
I was told this is a sportline but i cant tell form the pics thinking about buying this car soon. any help would be great wdbda29d7nf965859
thanks
1993 190E 2.3 Limited #566/700
thanks
What year is the car? does it have the sportline badges? Leather seats? 8 hole alloys?
Just a few easy questions you should answer to see if it really is a sportline.
car is a 92 it has leather but not black with a red stripe like all ht other sportlines i have seen. also wood trim vs carbonfiber. has sportline badges but.... also has 15 holes. i think it might be an le/se but not a sportline.
Data card
Attached Files wdbda29.pdf (21.8 KB, 0
views)
SHAUNE55, i appreciate the try but that card is for a 300sl and has a diff vin.
thanks for the replies though guys, nothing on the rev and i posted here 4 hours later.
2001 E55 AMG
iews)
SHAUNE55, i appreciate the try but that card is for a 300sl and has a diff vin..........Sorry I've no idea what happened there...I've tried your VIN again several times it's now coming up as invalid...check you posted the correct one and I'll run it again.
SHAUNE55 thanks for the info. for some reason I thought it would say sportline not evo1 under sport package. it is def not an evo of any sort. I guess it is worth a look though.
2001 E55 AMG
info
Sportline option
Mercedes-Benz offered an option called "Sportline" for the W124 and W201 chassis cars. This option was available in the North American market for the 1992-93 model year 190E 2.6, 1992-93 300E/300CE and 1993-95 E320/E320 Coupe. In the European market, however, the "Sportline" option was available for all body styles. The option package included sport seating (sedans, not coupes), wider wheels (7" rather than 6.5") and lower profile tyres (205/60 x 15 rather than 195/65 x 15), quick ratio steering, "Sportline" badges on the front wing moldings and gear knob, a slightly lowered ride height and a specially tuned suspension including shorter, stiffer springs, struts, anti-roll bars, and bushes.
The suspension components of the Sportline package were available as an option on all cars, including estates, as Option 653 - Sports Chassis with 8-Hole light alloy rims.
2002 ML320 Silver/Grey
Very informative post, thanks.
Sportline option
So I have determined that it is in fact a sportline with some help from the fine folks on this forum. Now the question is it worth it. The car is in ok over all shape it has 293xxx miles on it and a hole in the hood from the strut coming through. Owner says that was from PO. Also trany kicks and the idle is low. Also noticed that the oil pressure dropped to 0 at one point on my test drive. It did not stall on me once though. He is asking $1000 for it and I am almost there.
Another thing to consider is that I have a 91 CA edition 2.6 already and thus a lot of parts.
SO should I get it?
thanks
1 - 10 of 10 Posts
