Hello fello enthusiasts .. I have a 1973 280SE with the M130 engine .. It Developed a Dry compression leak out of the passenger side of the head gasket .
I rolled engine over to TDC of #1 cyl and verified cam lined up to pointer on bearing cap before pulling the cylinder head off .. I’ve reassembled the engine , taking great care to ensue nothing turned for ease of assembly . I was surprised when I tried to start it as it appears to have little to no compression . I dribbled some oil in each cylinder to see if that would help but it has not . I’ve pulled the valve cover twice now to ensure correct align and it is fine . I’ve looked at cam lobe position as I roll it over by hand and it seems fine as well . I’ve seen in online discussions that the M130 has had many upgrades and changes during its production life . I’ve used an aftermarket gasket which seemed fine but I wonder . This engine despite having a compression leak ran fine before I disassembled it .. It rolls over like there’s no spark plugs in it ..
Ideas?
Much appreciated
Steve
Ideas?
Much appreciated
Steve
