E350 2007 4Matic sport Gray with Black Interior
I have had the car for 6 months with out any issues. Yesterday on the way to work the car kind a shook and the check engine light came on. The car doesn't start easy now..it cranks a few time before it it's on. I ran the diagnostic check and got the following errors codes.
E350 2007 53k_miles 4Matic W211 E-class
Code 0272-continous camshaft adjutment(right)Incorrect position of the intake camshaft(P000A)
Code 0703-B70 (crankshaft fault hall sensor) indicator check wiring oflamp on signal line and voltage.
I am taking the car to dealer 1st thing monday morning and will not be driving it over the weekend. I am not sure what surprises I have got coming my way but want to get some expert opinion from kind folks here. Any suggestions or advise will be deeply appreciated.
'71 Pinto
May be the camshaft adjustment solenoid – if your engine serial # is 2729..30 759427 or lower original solenoid is replaced with improved part #2720510177. If you want, PM VIN and I can check your engine #.
I get the same issue:
E350 2007 220,000km 4Matic W211 E-class - Check Engine Light comes on
Code 0272-continuous camshaft adjustment(right)Incorrect position of the intake camshaft(P0012)
Code 0912 G3/3 (Left O2 sensor, before TWC [KAT]) : Signal Impulse (P2415)
Code 0908 G3/4 (Right O2 sensor, before TWC [KAT]) : Signal Impulse (P2414)
