Which North American M116/M117 camshafts are compatible with which engines? I understand the early mechanical lifter cams might have a longer duration and less lift than the cams used with hydraulic lifters.
In other words, can I pull a 4.2, 4.5, 5.0, or 5.6L cam and use it in my 3.8 as long as it has hydraulic lifters? I'm in desperate need of a passengers side cam and I need to confirm compatibility.
Thanks so much.
Thanks so much.
